VeriStand
Save Calibration Message Box:: Close programmatically
We do calibration everytime prior to system definition deployment automatically and store the new configuration in a calibration file. My automation test is hanged up everytime system definitions is undeployed and veristand asked user to save/not save calibration file.
Can someone tell me if there is a way to close Save Calibration's message box programmatically (with Yes/No).
rajamodol
LabVIEW 2016
Veristand 2016
(4,467 Views)
I'm Also Facing the same issue. Someone please reply.
(4,145 Views)
Im also looking for the solution for the same issue.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(4,115 Views)
A year ago or so, someone was asking about this. I believe I was able to do this programmatically without having to interact with this popup using the attached VI. However, this isn't tested and I can't guarantee it will work for your application. I am unaware of any other possible approach.
(4,099 Views)
I checked your code, its still promting Calibration message box.
Balaji PK (CLA)
(4,088 Views)
