VeriStand
Searching for occurrences of variables or expressions
I have a system definition of over a thousand signals. I see that VeriStand 2011 has some search functionality built in. Is there a way to search not just ni the channel names but for the use of particular variables within calculated channels? For example, if I have UserVar1, I'd like to be able to find all occurrences of where UserVar1 is used. It could be an argument in a Calculated Channel, a mapping destination, an alias, etc. Is there a search tool that can accomplish this? Thanks.
(5,851 Views)
Hello hyog,
I see what you are saying, that searching for a name of a variable within Calculated Channels, as one example, from the VeriStand Ctrl+F search dialog does not find it. Let me check in with our product support engineer if that functionality would be better placed as a feature request (currently intended behavior) or not, which could be filed as a Corrective Action Request. This would be very usefuly for large system definitions of your caliber and troubleshooting/making changes.
Thank you,
Deborah Y.
Deborah Burke
NI Hardware and Drivers Product Manager
Certified LabVIEW Architect
(5,842 Views)
Hello hyog,
Please submit this on the NI VeriStand Idea Exchange. We appreciate this valuable feedback on the product!
Thank you,
Deborah Y.
Deborah Burke
(5,815 Views)
Also, outside of the VeriStand environment, another option for mass searching variable names would be to search the System Definition's XML file.
Thank you,
Deborah Y.
Deborah Burke
(5,812 Views)
