VeriStand
Set specific colours on chart diagram
Hi all,
I'm using Veristand UI interface to design my project. In this project I have  a lot of pannels with different channel and I would have the capability to set a specific colour for every each channel so to have a clear rappresentation in chart diagram . AlternatelyI can accept to show the cannel name on the chart. Have you an idea?
Thanks in advance !!
(3,185 Views)
Hi, you can select the plot and on the right you have the chance to change the color and the style of the plot itself.
Hope it helps,
have a nice day!
FBM
(3,149 Views)
maybe the solution is refered at standar veristand interface, I use the UI (new Veristand interface, 2016 version)
I'm able to set the plot color on graph object present in standard GUI, but not in chart object present in UI.
R
(3,125 Views)
