VeriStand
Shortening Channel Names on Logging Specification
I am supporting a project where the user is using a few logging specs for their tests. They're using VeriStand 2020.
When adding channels from the aliases they end up with a whole bunch of signals that are called something like "Aliases/Folder 1/Folder 2/..../Signal 1" (example). Is there a way to get these channels to be called "Signal 1", "Signal 2" instead? Shortening the name from the Alias file path to the signal?
(853 Views)
https://www.savvydiademsolutions.com/ made a DIAdem script for me to clean up channel names [attached]
RenameChns DataPortal.VBS will shorten the channel names in the Data Portal
RenameChns Navigator Search.VBS will shorten the channel names in the result of the DIAdem Navigator Search
Lib_MechatronicSolutionsLLC.VBC must be in the same folder / root directory as the VBS script for it to function properly
Note, if you use the VeriStand Editor logging specification file as the data logger [https://www.ni.com/docs/en-US/bundle/veristand/page/data-logging-options.html] the channel names are not as lengthy
(821 Views)
