VeriStand
Simulink NIDAQmx VeriStand
I made a s-function in simulink with NIDAQmx.lib and NIDAQmx.h, and i can build it and generate a dll successfully with NIVeriStand.tlc.
I can use the dll with Windows target, but i can not use the Pharlap target, the deploy error is :
The VeriStand Gateway encountered an error while deploying the System Definition file.
Details: Error -307703 occurred at Project Window.lvlib:
Project Window.vi >> Project Window.lvlib:Command Loop.vi >> NI_VS Workspace ExecutionAPI.lvlib:NI VeriStand - Connect to System.vi
(5,967 Views)
(5,963 Views)
I do not have the problem in your first link, i can use my simulink model with no error, except i use the NIDAQmx.lib.
and your second link is lost, i can not open it.
(5,937 Views)
