VeriStand
Simulink array output as columns (1x300) and Labview models inputs as rows (300x1)
Hello.
I have a problem with models array inputs/outputs.
When I generate a model from Simulink with an output as array it is defined as columns (1x300) and when I generate a model from labview to veristand with an input as array it is defined as rows (300x1). I need to map both values but Veristand reports that both signals cannot be mapped due to size missmatch.
Any idea about how to change the array definition?
Thanks in advance.
Miguel.
(3,141 Views)
Hello.
Any idea about this issue?
Miguel.
(3,030 Views)
