VeriStand
Simulink enums deleted when building with latest version
I am upgrading from Veristand 2019 R3 to 2023 and trying to build some models that were working fine with 2019, but now I get a warning that enums are not supported by Veristand and the input/output ports are not created when I try to build the models.  I just need the numeric value to pass into/out of the model and I had no problem with these models when building for 2019 with the older Veristand model framework.  I was able to just use the numeric value of the enum, but now the signals are just removed from the build and I can't access them.  Is there a work around that I can use?
Message 1 of 1
(1,381 Views)
