VeriStand
State machine architecture in VS?
Recently I started migrating with a HiL-Project from Labview onto Veristand. Deployment of a first simplistic Veristand project for interfacing with Hardware works fine.
But how about a state machine architecture in Veristand...In Labview one can use hardware/software conditions for transitioning from one operating state (e.g. "Test" or "Initialization") to another (e.g. "Running"). And in each state variables can be set for the GUI (e.g. a string indicator showing the active state name)...but how is this logic implemented here? Are the Procedures the answer or do I need to import VI's from Labview somehow?
Thanks in advance
(2,681 Views)
After finding out that, yes, Procedures allow for a state machine architecture 🙂 How can I monitor in runtime, which procedure is active at a given time?
BEst wishes
(2,669 Views)
Accepted by topic author Lysandros
I would keep procedures as simple as possible as they might became hard go maintain for more complex logic. Instead I would think of incorporating your decision-making logic in the stimulus profile respectively in the real-time sequence.
If you would need more complex state machine, you can also consider to implement it as LabVIEW model and compile it for NI VeriStand.
CLA, CTA, CLED
(2,661 Views)
