VeriStand
Stimulus profile logging: UUT folder not always created
I am noticing a behavior that I don't understand regarding logging from stimulus profiles. By default, when a new stimulus profile logging configuration is created, the file path is "Log Files.tdms." In this case, I can, in the Execution tab, tick "Show UUT Dialog." If so, the TDMS file gets stored in a subfolder with the name of the UUT. If I modify the file path to a different directory, however, the dialog still prompts me, but the log file is not placed into a subfolder. I'd like to know how to ensure that the log file is placed into a UUT named folder regardless of what path I specify.
Thanks.
(5,341 Views)
I think I know how we can make this work now. It seems that in the Logging File Path field, we should not enter the full path but just the name of the file, e.g., "Log.tdms." The path should be specified in the profie's Results Directory (not in the logging properties). Doing so seems to allow the UUT directory to be created. I think what's happening is that when we specify a full log file path then the results directory and UUT directory creation gets overwritten by the absolute log file path which doesn't include the UUT name.
(5,324 Views)
