06-10-2013 02:39 PM
Sometimes in the course of writing sequences, we need to rename a parameter and all its references. Even after doing so and everything compiles, the profile fails in runtime because somewhere the program is still trying to access the original parameter name. The fix for this is to remove the sequence call from the profile entirely and reinsert it. Then the profile runs fine.
e.g.,
06-11-2013 06:04 PM
Every time you change a name of a parameter in a Real-Time sequence you need to make sure that you select this test sequence call in your stimulus profile code and click the "Update Parameters" button. This will make sure the new parameter name is used in the stimulus profile call of the test sequence.
06-11-2013 06:06 PM
Hi Sev,
I'm pretty sure I do do this. What about the case when a sequence calls a subsequence? There's no "update parameter" option in this case, or am I missing something? Thanks.
06-12-2013 05:54 PM
Hi Harris,
Can you please try to reproduce the issue with the attached project.In the project you have a stimulus profile (Count_Test.nivsstimprof) that calls Increment_Count.nivsseq with two parameters. Inside the Increment_Count.nivsseq there is another call to Increment_Count2.nivsseq also with two parameters.If I change the name of the "Increment2" parameter (inside Increment_Count2.nivsseq) to let's say "Increment3" the sequence runs as expected, even tough the calling sequence(Increment_Count.nivsseq) still has "Increment2" name in it. Can you check if you see the same behavior?
06-12-2013 07:34 PM
Hi Sev,
Unfortunately when I try to open your profile in Stimulus Profile Editor, it crashes SPE. I've had issues like this before if there are recursive calls. I believe we have a forum thread about this issue .I'm assuming it's similar.
Description:
Stopped working
Problem signature:
Problem Event Name: APPCRASH
Application Name: Stimulus Profile Editor.exe
Application Version: 2011.1.0.1
Application Timestamp: 50a2cc79
Fault Module Name: KERNELBASE.dll
Fault Module Version: 6.1.7601.18015
Fault Module Timestamp: 50b83c8a
Exception Code: e053534f
Exception Offset: 0000c41f
OS Version: 6.1.7601.2.1.0.256.4
Locale ID: 1033
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
06-13-2013 01:01 PM
Hi Harris,
I was using two separate RT sequences so there should be no recursion. I've recreated the project on my colleague's computer. Let me know if you can open it.
06-13-2013 01:17 PM
Hi Sev, your project/files work withuot errors. I noticed one difference, however. When the failure happens for me, it is with all By Reference parameters. I notice in this case that Increment2 is actually by value. Perhaps that's significant in this case? Thanks.
06-14-2013 11:25 AM
I've tried switching the Increment2 to "By Reference" and I got the same results when I changed the name to Increment3. You need to make sure that if you are using a "By Reference" variable in a subsequence you also have a "By Reference" variable in the calling sequence..
06-14-2013 03:17 PM
