VeriStand
Updating Database
So I updated my XNET database and if I open the database from the , when I open with database editor from the configure window it is showing that I have the signal that is required, but the new signal that I have added is not available in the configure window even though I went to XNET database in configure and did refresh database. Any help would be appreciated.
(1,492 Views)
Hi handsome_puddle077
Are you receiving an error? If yes, what kind of error is that?
Also, I see this post is quite old, therefore I hope the problem have been solved.
Regards)
(1,239 Views)
