VeriStand
Using Simulink in Veristand For Dummies
Hi, I don't have a CAR or Service Request number, but the problem is very similar to 206055: "When loading a model built using Simulink 2009a and compiled as a DLL into System Explorer, initial values for parameters are bad." In fact, what happened to me was that the initial value of each parameter (i.e. a constant) was not set to the value I gave in the MDL. I needed to give the right value from the workspace. If I compile the MDL with a previous release of Matlab all was ok. Thanks.
Message 11 of 13
(4,112 Views)
Hi JohnnyGroove,
The issue you are referring was reported by NI Italy as CAR 206055 and is being investigated by National Instruments R7D. The VeriStand 2009 f1 patch does not address that issue, sorry.
Joshua B.
Message 12 of 13
(4,107 Views)
Many thanks Joshua! I guess NI Italy rised up this issue after having heard my problems with R2009a. Thanks again.
Message 13 of 13
(4,105 Views)
