VeriStand
VS2016 project deploy on PC
I need to use teststand with veristand and to write the sequence I can not use the real target because busy for test so I would try to use a laptop.
I've installed LV2016, VS2016 e TS2016 (32bit) and I'm able to open a VS project.
I set the target has local host e try to deploy but an error occurred (see log).
Any suggestion?
(1,914 Views)
The error say the "PXI1Slot11"device is simply not present on your system. You can try to simulate it thru NI-MAX or just for your test disable DAQ devices in your SDF.
CLA, CTA, CLED
(1,878 Views)
Hello and sorry for delay in this response.
I've created the peripheral board with MAX (no shelf and controller because in MAX my controller is not available). The board are in same virtual slot of real case.
Now the error is different, seems a synchronization problem.
(1,862 Views)
Accepted by topic author zundap1970
Error found, was due a DAQ setting.
I've checked the "Disable AI Support" and It works
(1,856 Views)
