VeriStand
VeriStand 2011 coming out soon?
I'm starting a small new project and would like to test VeriStand (have not used VeriStand before) and the new LabVIEW 2011 (have used LV 2010 before). Is it possible to use LabVIEW 2011 with VeriStand 2010? Or do I need to wait for VeriStand 2011? If yes, does anyone know when it will be released?
Greetings
Frank
(6,492 Views)
Accepted by topic author frankkremer
Hi Frank,
NI VeriStand 2010 can only be used with LabVIEW 2010, so if you still have LabVIEW 2010 installed, I'd encourage you to download the evaluation version of NI VeriStand 2010 to test it out. However, if you want use LabVIEW 2011, you can expect NI VeriStand 2011 to release in the next few weeks.
Cheers,
Olivia
(6,485 Views)
it is up now
http://www.ni.com/veristand/
Stephen B
(6,339 Views)
Hey, thanks!
(6,329 Views)
