VeriStand
VeriStand 2016 error ex8sn9
Hello, I have successfully installed VeriStand 2016 and I'm using Matlab R2013b (I've already checked the compatibility) but, when I open Matlab I obtain the following message:
Warning: A problem occurred initializing or executing an NI VeriStand component. Error detected was: Error using NIVeriStandAddPaths (line 84)
VeriStand: Unable to initialize the NI VeriStand Model Framework. This release of Simulink(R) is incompatible with NI VeriStand. For more information, visit ni.com/info and enter the Info Code ex8sn9.
I looked into the function NIVeriStandAddPaths.m and it seems that when I use it with no input (as requested to automatically search the latest available version of Model Framework) there is the problem mentioned above but, if I use this function with 2016 as input (as requested when the user wants to select the VeriStand version) it works and everything is ok. How is it possible?
Thanks in advice
(3,419 Views)
Accepted by topic author FedeCorr92
Do you have Simulink Coder installed?
(3,398 Views)
That was exactly the problem! Now it works.
Thanks a lot
(3,384 Views)
Glad to hear it - you're welcome!
(3,380 Views)
