VeriStand
VeriStand, Custom FPGA and DMA-Type of SGL?
We're currently using the PXI systems with the VeriStand engine, where the models and FPGAs communicate via DMA FIFO. The custom FPGA projects were created and the DMA FIFO was described with the XML-fpgaconfig. But you can define the type SGL in the FPGA project of the DMA FIFO. The transfer of the data with LabVIEW Realtime is thus possible, but how can the type be placed on SGL in the XML-fpgaconfig for the veristand-project. Does VeriStand support that?
Possible DMA type in FPGA project and xml-fpgaconfig.
System Explorer of the veristand project
VeriStand 2016, LabVIEW 2016 SP1 with FPGA module
(2,612 Views)
Looking at Creating a Custom FPGA Configuration File, there is no tag related to SGL so,
you can handle the SGL data as INT and then use "Scale" and "Offset".
FPGA SGL To Integer Cast
Certified LabVIEW Developer
GCentral
(2,590 Views)
