VeriStand
VeriStand Engine Questions
I am looking to send a large amount of data to the VeriStand RT Engine through the VeriStand gateway.  I have a few questions regarding the capabilities.
  • How fast can I send data to a single channel?  For instance, passing data through the VeriStand gateway to the Real-Time controller using this VILotsaMotsa_2-1668902573014.png
  • How large are the RT FIFO's in the VeriStand Engine?
  • Can I overflow the FIFO's?
  • Can an inline asynchronous Custom Device only receive data from the VeriStand Engine through the Engine's RT FIFO's?
    • Is there another way to pass data to a Custom Device?
  • How do you get data to a Custom Device at a high rate through the VeriStand gateway? i.e. VeriStand gateway to the Real-Time controller
  • How much data can I send to the VeriStand Engine at once?  I realize this is a vague question
Message 1 of 1
(1,373 Views)
