VeriStand
VeriStand: The build procedure failed to compile the model
error while building the .slx.
i developed switch case. In configuration setting target file is NIVeriStand.tlc.
it throws an error.
(2,100 Views)
What version of VeriStand and Simulink are you using? Does the compilation fail with another simple model?
https://tmesystems.net/
(2,077 Views)
version of VeriStand - 2017
MATLAB - 2017a
Does the compilation fail with another simple model? --- yes
(2,073 Views)
VeriStand LabVIEW Modeling and Legacy Simulink Modeling Version Compatibility
Matlab
Matlab 2017a is not compatible with VeriStand 2017.
(2,067 Views)
