VeriStand
VeriStand does not deploy with 7811R
Hello all,
I am currently experiencing some issues while trying to replicate a System of ours. This configuration has worked in that exact setup before and now I am experiencing loads of problems. The Project uses a 7811R with a custom personality I wrote last year. Here's what works and what doesn't:
The FPGA code runs on LV FPGA, without any problems.
In VeriStand: When I select just the chassis, it deploys fine.
When I add the 7811R with my own .fpgaconfig it returns an error after starting deployment group 1: Error -50400 Timeout
When I add the 7811R with an example config (e.g. PCI-7811R PWM, Digital Lines.fpgaconfig) it gives me a different error after starting deployment group 1: -61024 Something about a mismatch between configured and current device type.
I can't stress enough, that it all worked before in the exact same configuration.
Because of this I added a 7841R that we had lying around. This deployed just fine with the standard config (PXI-7841R Analog, PWM, Digital Lines.fpgaconfig in this instance).
From the errors or lack thereof described above, I surmise that:
a) The 7811R itself is OK, since it works with LabVIEW
b) VeriStand + FPGA works, as it works with the 7841R
c) All the installed software is OK, as well, since it works with the 7841R
What else can I try?
P.S.: I should mention that the same problem occurs on both my laptop and our demo system. Both are Running VeriStand 2015 SP1.
Remember Cunningham's Law
(3,242 Views)
Also, the Example config should be: PXI not PCI. Result is not the same.
Edit: It's not, when you select the right RIO device. Now I just need to get my custom personality going.
(3,216 Views)
Accepted by topic author PeterFoerster
OK, I don't really know what did the trick, but it works now.
After finding out, that I had previously selected the PCI personality instead of the PXI, the old project still wasn't working. So, I created a completely new one, which worked right away. After that, I basically copied my old code into the new project and now it works. The old one still doesn't.
What I don't quite get is: With the new software I get problems when loading the file, because of the Umlauts (üäö). The old version does not complain.
As I said, I don't know what did it in the end. I installed the earlier version of Xilinx (10.1) that might have done it. Also completely rebuilding the project.
(3,199 Views)
