VeriStand
Veristand 2011 with new Driver Aug13
How is the compatibility of Veristand 2011 SP1 with new driver for LabVIEW 2013?
Are there any problems? I couldn't choose Realtime-Module for Installation in Remote Controller.
I installed LabVIEW Realtime Module 2011 before.
What could be the reason??
Regards
YesB
(6,477 Views)
Which driver do you mean? Did you install the Realtime Module 2013?
Normally, the version of VeriStand has to match the version of e.g. LabVIEW, modules etc.
Michael
__________________________________
Certified LabVIEW Associate Developer
(6,458 Views)
Now I Installed
LabVIEW 2011 SP1
Veristand 2011 SP1
Realtime 2011 SP1
DAQmx 9.6.2
etc.
I installed LabVIEW Driver from Februrar 2012
I have Exception after Start MAX 5.4, look at attachement.
What is my failure. I installed all required Software and I have problem at all.
(6,447 Views)
Could you please post a MAX-Report of your system? So I can have a look at your system's configuration.
A description on how to generate one is here: http://digital.ni.com/public.nsf/allkb/271F252B4EF0A2E0862570E70056A1E4
Please choose Technical Support Report in the menu.
BTW: Sind Sie deutsch?
(6,441 Views)
yes, I am from Germany.
I couldn't generate a MAX Report, because the MAX hangs up.
Regards
YesB
(6,422 Views)
try to reinstall the software - but this time with the matching versions (e.g. LabVIEW 2011 and driver from 2011, not 2013).
Auf Deutsch: Die Jahreszahlen von LabVIEW und den installierten Treibern sollten immer zusammenpassen. Versuchen Sie die Software neu zu installieren, diesmal aber mit der passenden Version.
  michael
(6,401 Views)
Hallo,
habe ich schon gemacht.
Schein ein komplexeres Problem zu sein.
Gruß,
YesB
(6,397 Views)
