VeriStand
Veristand Depyloyment Error
Hi everyone
I am trying to use FGPA addon custom device with Speciality IO template my purpose is generating pwm singal with FPGA
I followed fpga addon custom device QuickStart  and  Speciality IO template Example documents
I configured system explorer according to these documents but when I trying to deploy my project into RT system I get deployment Error below:
How can I solve this error. Thanks in advance.
My system:
Veristand 2021 R2
PXe-8881/PXIe-7820R
Deployment Error
Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> Project Window.lvlib:Connect to System.vi
<append>=========================
NI VeriStand: NI VeriStand Engine.lvlib:VeriStand Engine Wrapper (RT).vi >> NI VeriStand Engine.lvlib:VeriStand Engine.vi >> NI VeriStand Engine.lvlib:VeriStand Engine State Machine.vi >> NI VeriStand Engine.lvlib:Initialize Inline Custom Devices.vi >> Custom Devices Storage.lvlib:Initialize Device (HW Interface).vi
NI VeriStand: Error occurred at the following location:
"Targets/Controller/Custom Devices/FPGA Addon"
Error 6001 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> Project Window.lvlib:Connect to System.vi
This error code is undefined. Undefined errors might occur for a number of reasons. For example, no one has provided a description for the code, or you might have wired a number that is not an error code to the error code input.
Additionally, undefined error codes might occur because the error relates to a third-party object, such as the operating system or ActiveX. For these third-party errors, you might be able to obtain a description of the error by searching the Web for the error code (6001) or for its hexadecimal representation (0x00001771).
(1,113 Views)
Accepted by topic author Konaks
May be you used an earlier version of FPGA Addon and the error message was not routed to the VeriStand engine.
I believe that this is caused by the naming mismatch between the channel names in VeriStand and the front panel items of your FPGA VI.
https://tmesystems.net/
(1,084 Views)
I updated Veristand Custom Devices version 2021 R2 to 2024 Q4 now its working thank you very much. I have one more question I added pwm out as shown below but I couldn't understand clearly which pin does this channel represent
(1,055 Views)
Check your FPGA VI source code and jot down the pinout. The compiled bitfile does not contain any pinout information.
(1,028 Views)
