03-20-2013 11:09 AM
I have a system currently running NI Veristand 2011 SP1 that has recently begun locking up (after months of use and no significant system configuration changes). After Veristand locks up on the PC, i am unable to reconnect to the controller without getting an error (-307850). I can still ftp to the controller, so I know my ethernet connection to it is still present. Connecting a monitor to the RT controller (PXIe-8133) reveals no error messages of any kind, but also 0% processor usage on all cores. It seems as though the Veristand Engine has simply locked up on the RT controller. I've had this happen a few times, and it seems like the only solution is to reboot the RT controller. Has anyone seen this issue before? If so, does anyone have any suggestions on debug steps I can take in this scenario?
03-21-2013 12:08 PM
You claim FTP is still active - have you actually tried pulling a file, or did you merely just browse the file system? What results do you get when you ping the target - do you get a response?
-Danny
