VeriStand
Veristand: Error - 1074384895 when I try to Monitor a message in Veristand Custom Device
I have a Veristand project that uses the J1939 Custom Device. It deploys and works as normal when simulating messages, however when I have a message in Monitor, it gives me Error - 1074384895. I tried putting it in the Monitor->Incoming and I have also tried in Monitor->Outgoing. It also gives me the same error when I have the message in Simulate->Incoming. When i delete the message out of the System Explorer it deploys as normal. I use the XNET Database Editor for my database of messages.
(1,682 Views)
Error - 1074384895 is pretty hard to troubleshoot. It might not relate to the J1939 Addon custom device. Try the steps in Error -1074384758 or -1074384895 using NI-XNET Create Session. You can skip the steps that are related to modifying the code.
https://tmesystems.net/
(1,671 Views)
