VeriStand
Veristand Target Error -307850
 I am running Veristand on my PC with PXIe 1062(not using RT controller). When I execute the system definition I get the following error:
NI VeriStand:  The target cannot be reached. Verify that the Ethernet cable is connected to the real-time (RT) target and that the RT target is enabled and running.
NI VeriStand:  Server TCP Interface.lvlib:TCP Connection Manager.vi:1
<append>=========================
NI VeriStand:  A communication failure occurred while handshaking with the target.
Target: Controller
Any pointers to solve this problem  will be very helpful
Message 1 of 10
(8,417 Views)
Is the target OS on the Controller page in System Explorer set to Windows?
Jarrod S.
Message 2 of 10
(8,405 Views)
Hi ni_2012,
If I understand correctly, you are running this on a Windows PXI controller.  Is this correct?
Just to be 100% certain, in your System Definition, your target is set to Windows and localhost, correct?
The Project Explorer is still going to communicate to the VeriStand engine running on your computer using TCP/IP.  So, you should make sure that you do not have a firewall blocking this communication.  The easiest way to do this would be to disconnect your computer from the network, turn off your firewall, and then try again.
Have a great day,
Chris V
Message 3 of 10
(8,401 Views)
@ Jarrod,
Thanks for the reply. It is set to Windows.
Message 4 of 10
(8,389 Views)
@Chris,
Thanks for the reply. My PXI does not have a real time controller. Veristand is using my PC as a host target.
Message 5 of 10
(8,387 Views)
Hi ni_2012,
Okay, then I'm a little confused. How are you using a 1062 from your host PC?
Do have a MXI connection to the 1062?
Do you have a controller in the 1062 running Windows?
Have a great day,
Chris V
Message 6 of 10
(8,374 Views)
@ Chris
My PXI does not have a controller. I am running Veristand on my PC. I have generated a Labview dll and I am using Veristand to map hardware to my input. I have defined the PXI Slot and signal( anlaog / digital etc) on my Labview VI. But when I load the dll and execute System definition I get an error saying that it is not accepting the way I have defined my hardware.
If I cannot use hardware assignments in my VI, is there any placeholder from Veristand block set that I can use?
Then the next error which pops up is it is unable to reach the target. (The target is PC)
Message 7 of 10
(8,368 Views)
Hi ni_2012,
What is in slot 1 (the red one with the triangle) of your 1062 chasis?
Have a great day,
Chris V
Message 8 of 10
(8,362 Views)
Hi Chris,
Slot 1 of my chassis  has a  PXI 8360 which uses MXI and connects to my desktop.
Have a nice day !
Message 9 of 10
(8,355 Views)
Hi ni_2012,
Okay, that clears things up a lot.
In VeriStand,  you'll want to make sure the name you give the DAQ card you are using (which is?) the same name it has in Measurement & Automation Explorer.
I'm assuming you're mapping the DAQ channel to the LabVIEW model input then?
Did you build a LabVIEW dll with the Application Builder, or did you go into LabVIEW and select Tools > NI VeriStand > Generate NI VeriStand Model from VI...?
Have a great day,
Chris V
Message 10 of 10
(8,344 Views)
