VeriStand
Veristand custom device or workspace control to run a stimulus profile.
Does anyone have a VeriStand custom device or workspace control that allows the user to run (start/stop) various stimulus profiles from the workspace?
(4,278 Views)
In order to run a Stimulus Profile, you must be able to call .NET code to communicate with the VeriStand Gateway. This would not work from a Custom Device running on a real-time target.
However, it is straightforward to call stimulus profiles from a Workspace control. The following example installed into LabVIEW shows you how to call stimulus profiles and manage their execution.
<LabVIEW>\examples\NI VeriStand\API\Execution API\Sequences\Stimulus Profile Control Tool\Stimulus Profile Control Tool.vi
I am not sure which version of VeriStand you are using. We had a bug in some versions where this example VI was broken. However, the fundamentals of the example still apply. This example is in the form of a Workspace Tool, not a control. However, changing it should not be too hard. For an example of how to build a custom Workspace control, refer to the Free Label VI in the Display Templates folder in Public Documents\<VeriStand>.
Jarrod S.
(4,259 Views)
Jarrod,
Thanks for the response.  I am running LabVIEW 2015 and VeriStand 2015.  I took a look at the example that you pointed out to me.  It was broken when I opened it, but once I simply reconnected the broken wires it appeared to be ok.  What steps do I need to take to get this tool into my VeriStand Project?  Do I need to run the build specification in the project, and then copy something to the Public Documents\<VeriStand>\<Workspace Tools> folder?
Also, what is the difference between a workspace tool and a workspace control?  How exactly do I change this VI so I can use it as a control instead of a tool?  I looked at the "Decoration Free Label" vi in the display templates folder, but it's not clear to me what to do...?
Dan
(4,251 Views)
