VeriStand
Veristand load to HIL ,occured Error116
hi all. I'm trying to deploy my Veristand project on PXI8840.every time,it occured error 116.
The VeriStand Gateway encountered an error while deploying the System Definition file.
Details:
Error 116 occurred at Project Window.lvlib吐舌表情roject Window.vi >> Project Window.lvlib:Command Loop.vi >> NI_VS Workspace ExecutionAPI.lvlib:NI VeriStand - Connect to System.vi
Possible reason(s):
LabVIEW: 由于损坏的、未预期的或已删节的数据导致还原或字节流读取操作失败。
NI VeriStand: Read from Binary File in Engine Data Compilation.lvlib:Read Engine Binary File.vi->NI VeriStand Engine.lvlib:VeriStand Engine State Machine.vi->NI VeriStand Engine.lvlib:VeriStand Engine.vi->NI VeriStand Engine.lvlib:VeriStand Engine Wrapper (RT).vi<APPEND>
c:\ni-rt\NIVeriStand\SystemDefinitionData.nivscfg
(3,704 Views)
is there any error code returned (6 numbers)
(3,652 Views)
Is there any specifc error code ? (6 numbers starts with 307)
(3,651 Views)
There is most probably different version of NIVS installed on target compare to your computer....
CLA, CTA
(3,639 Views)
