VeriStand
Veristand mapping issue
I'm using Versitand 2015SP1.
I've configured XNET in the sdf, but when i open the "mapping" tool, I can't find the XNET channel.
Do someone have the same issues, and what's the solution?
(1,174 Views)
Just a couple thoughts:
1.) When you configured XNET, did you associate it with a database?
2.) You can map incoming and outgoing database signals in the sources side of mapping, but only outgoing channels in the destination.  You can map incoming channels inside of the calculated channels though.
(1,154 Views)
