VeriStand
Veristand multi target management
I'm actually developping a veristand application running on a multi RT target system.
I'm only using a single project and definition file to handle this.
I've noticed that if a target is not running while trying to deploy the system, the whole system won't start.
I've also noticed that after having successfully deployed my project, if one of my target gets down below, my project is disconnected and I'm not able to communicate with remaining alive targets .
Is there a way to handle this, keeping on communicating with alive targets by disabling the dead unit?
(6,209 Views)
Check out the NI VeriStand 2012 beta when it comes out
Stephen B
(6,187 Views)
Ok thanks for the answer.
Do you know when it will be released?
And do you know exactly all the new features that will be included especially regarding the multi RT target management?
(6,177 Views)
