VeriStand
Veristand report generation
Hi all,
for a project I need to run a set of tests on a pneumatic bench controlled by a cRIO running a compiled Simulink model and record measurements from transducers. The measurements are numeric recordings, no graphs are needed.
I've used Veristand for similar application before but for this project I would also need to automate the report generation process which could be, ideally, directly fill a Word template.
Any advice on how to implement the report generation?
Message 1 of 1
(503 Views)
