VeriStand
Veristand returns Error 1003 when attempting to deploy and run examples(sinewavedelay etc)
    we deploy the example sinewave of Veristand 2015 to Host PC(Win7 32bit) ,It's OK,but when deploy the same example to RT target(PXI-8115) returns error 1003,log are as followed . How to resolve this problemAny help would be greatly appreciated.
   thank you
 Details:
Error 1003 occurred at Project Window.lvlib:Project Window.vi >> Project Window.lvlib:Command Loop.vi >> NI_VS Workspace ExecutionAPI.lvlib:NI VeriStand - Connect to System.vi
Possible reason(s):
LabVIEW:  The VI is not executable.  This error may occur because the VI is either broken or contains a subVI that LabVIEW cannot locate. Select <b>File>>Open</b> to open the VI and verify that you can run it.
NI VeriStand: Launch Asynchronous VI by Name.vi->Model Execution.lvlib:Launch Model Loops.vi->NI VeriStand Engine.lvlib:VeriStand Engine State Machine.vi->NI VeriStand Engine.lvlib:VeriStand Engine.vi->NI VeriStand Engine.lvlib:VeriStand Engine Wrapper (RT).vi中的打开VI引用<APPEND>
Model Execution.lvlib:Model Execution Loop.vi
Message 1 of 1
(3,770 Views)
