VeriStand
Way to set custom item property in *.fpgaconfig file?
Is there a way to create and set a custom item property (like what you would create using the "NI VeriStand - Set Item Property" VI) from a *.fpgaconfig file for an FPGA data channel?
(5,514 Views)
Hello NFT!
There is functionality to do this.  Check out a summary in the LabVIEW Help, "Setting and Retrieving Properties on FPGA I/O and FPGA Targets (FPGA Module)".  Or, check out the web version of this document here: http://zone.ni.com/reference/en-XX/help/371599J-01/lvfpgahelp/creating_fpgaio_property_nodes/
Best,
Ryan C.
(5,485 Views)
Sorry, this isn't what I was looking for. I was trying to set item properties for FPGA channels in VeriStand through XML files.
After having a conversation with another NI engineer, I found out that what I was looking for isn't available in VeriStand.
Thanks, though.
(5,480 Views)
