VeriStand
What determines the upper limit for the PCL rate?
I want to run a 10 kHz PCL at PXIe-8880. I also need to use 480 I/O on the PXI. And when I start to add Veristand channels for these I/O, first HP Loop duration exceeds 100uS and my PCL rate goes to 5 kHz and if I continue to add channels then it goes to 3.333 kHz. When these events take place, the core running the PCL goes from 98% to 54% and then 32%.
I am wondering if the only limiting factor for PCL rate is the Veristand channel count in my case or is there anything I can do to solve this problem?
I have a PXIe-1085 chassis with PXIe-8880 on.
Modules are:
2 x PXIe-6365
2 x PXIe-6739
2 x Pickering 40-412-111
Message 1 of 1
(1,668 Views)
