VeriStand
Why reading ECU parameters failing with XCP and CCP Custom Device?
I have installed  ECUMC 2.2.1 version and imported XCP and CCP Master Addon custom device to sysdef file.
I am using Veristand 2011 SP1 for testing ECU.
On the main page of custom Device I have done setting as shown below:
Under Communication Properties I have selected option "Use communication properties of database".
I have imported A2L file successfully and I am able to see parameters under measurement and Characteristics field.
We have total of 4 CAN ports out of which 3 are assigned for other CAN bus communications and 1 for Diagnostic.
At first intance I tried to use already assigned CAN port of Diagnostic to this custom device and its failed to read
parameters from ECU.
So later I freed one of the CAN port out of other 3 and assigned to this custom device.
After deploying the project I tried to read the parameters from ECU but it doesn't works.
Using on boolean control I tried to "connect" custom device with ECU but still connection status is 0 and error code displayed
was -301096.
So please guide me about the settings on main page of this custom device if anything is wrong.
If settings are correct let me what exactly could be the reason for this failure.
Thanks and Regards,
Nilesh
(7,791 Views)
Hi Nilesh,
I believe you are already in touch with Varun regarding this issue so we will continue to support you from there.
Regards
Gautam Grover
(7,730 Views)
i've your same problem. Finally did you solve it?
Any ideas ?
Thankyou.
Mike
(7,508 Views)
It's been long since you posted it last. Did you solve it??
I've had the simillar problem today.
The error number was 301005.
After deploying the project, the " connection status" is already 1 and showed error "301005" .
Once changing the "connect" to 1 as to connect, the error was clear.
I don't know why first the error was shown even though the connection status is 1 as already ECU is connnected.
If you have new information relating to this connection error, please let me know.
Thank you,
Noriyuki
(4,494 Views)
Does anyone knows a solution? Im getting similar errors.
My Channel: https://www.youtube.com/@LV_Lab
(3,695 Views)
