VeriStand
XCP and CCP Master Add-On for NI VeriStand feedback.
FYI:  The ECUMC installer does indeed specifically have a NI VeriStand option in the list of supported "programming language" targets.  It will be selected to install by default assuming NI VeriStand is already installed on the system.
Message 101 of 118
(1,858 Views)
Yes, thanks. I uninstalled and reinstalled with that option selected and will try at a later date to see if it works.
Message 102 of 118
(1,856 Views)
Hi hyog,
Have you managed to solve the problem?
I installed ECUMC 2.2.1 over VS2011SP1, and got problem right away.
I never installed any ECUMC custom device before.
Regards, Kate
Message 103 of 118
(1,830 Views)
Hi KateB,
The reinstall of ECU 2.2.1 seemed to have worked for me. It no longer throws an error upon VeriStand deployment to the RT target. I do get an error when I try to read or write values, but I think that's something on my end.
Message 104 of 118
(1,823 Views)
Hi hyog,
So sad...mine doesn't work so far...Smiley Sad
Applications Engineer | National Instruments
Singapore (65) 6226 5886 | Malaysia (60) 3 7948 2000 | Thailand (66) 2 298 4800
Philippines (63) 2 659 1722 | Vietnam (84) 28 3911 3150 | Indonesia (62) 21 2783 2355
Message 105 of 118
(1,811 Views)
Our ECU supports CCP and can be flashed using CCP.
Does this Add-On support that?
Craig
Message 106 of 118
(1,772 Views)
That is a good question that unfortunately has at least two answers.  In theory ECU flashing through CCP will work with this Add-on assuming we are simply talking about communicating values over CCP channels defined by the A2L file.  However, for the sake of ECU security, there is often a handshaking process including security logic (code) that occurs to unlock the ECU for programming.  That's probably a good thing so someone is not able to freely reprogram your ECU.  So I would expect there needs to be some customization of this XCP/CCP Master Add-on to accomplish this task.  NI has done this customization for customers in the past via our Engineering Services group so you may contact your local NI Sales Engineer to start this process if you are interested in discussing further.  Feel free to refer to this post.
John
Message 107 of 118
(1,768 Views)
Thanks John,
I think my next port of call is the ECU supplier.
Message 108 of 118
(1,757 Views)
hi stephan
We work with NIVS 2011 and Custom Device CAN CCP we want to switch our ECU from ROM to RAM (changin the calibration page adress) this feature is not possible with the current Add-on Smiley Sad
we have try to use a simple addon (CD) to do this but unfortunately the CCP Add-on go in error  and disconnect the ECU: our switch from ROM to RAM is working but we lost the ECU connection :
there is any way to reconnect the ECU after veristand deployement ???
I know from the ECU M&C Toolkit 2.2 New features within the XCP/CCP Custom Device for NI VeriStand:
there is a feature that allow to auto reconnect the ECU again (if ERROR) (how we can Support to set the Delay before reconnect time. This time defines the time to wait after an CCP/XCP communication error before trying to connect to the ECU again.)
HOW WE CAN DO-IT ???
Thank you in advance for your efficent collaboration
Description : cid:image001.png@01CBDD85.B299BDC0
Abdelilah ESSAMHI
Performance Rig Facilities Team Leader
 Centre Technique – Delphi France SAS
 9, boulevard de l'industrie 41000 Blois
( :   +33(0)2 54 55 32 91
 5 :   +33(0)6 60 83 84 14
Fax : +33(0)2 54 55 36 22
Phil Moisey
Message 109 of 118
(1,730 Views)
Hi Phil,
Now that this add-on is a shipping NI product and now just a web download, for support on the XCP and CCP Master Add-on for NI VeriStand, you should use the normal NI support channels. Please create a service request at ni.com/support so the developers of the add-on can assist you and hear your feedback.
As far as the connect functionality, this was added in ECUMC 2.2.1 http://joule.ni.com/nidu/cds/view/p/id/3451/lang/en
Stephen B
Message 110 of 118
(1,728 Views)
