VeriStand
XNET Database Error - Empty Name - 0xBFF63163
I have run into an issue where my Veristand project cannot deploy when I add a new CAN frame to my system definition and create trigger/disable channels for it. I get the following error:
NI-XNET:  (Hex 0xBFF63163) You used an empty name for an XNET database object (database, cluster, ECU, frame, or signal). Empty name is not supported. Solution: Refer to NI-XNET help for IO names to review the required syntax for the name, and change your code to use that syntax.
If I remove the Disable/Trigger channels from the CAN Frame specification, the project deploys.
Both the Disable and Trigger User channels are created in the system definition:
DM11_XNET_ISSUE_SystemDefDM11_XNET_ISSUE_SystemDef
Here is the CAN Frame in the NI-XNET Database editor
DM11_XNET_ISSUE_DatabaseDM11_XNET_ISSUE_Database
Can anyone see what I am doing wrong here to cause the issue or have tips to try to resolve this?
Thanks!
(3,491 Views)
Would you be able to post your system definition and your XNET Database file?
Michael Bilyk
Former NI Software Engineer (IT)
(3,467 Views)
