VeriStand
XNET LIN can't deploy on RT
Hi ,
 After install XNET LIN card , and install xnet driver 1.4 on the RT. When deploy configration, I meet a problam:
Error code: -1074384857
Error message: NI-XNET:(Hex 0xBFF63027) you incoke two or more VIs simultaneously for the same session, and those VIs do not support overlap. for example, you attamped to invoke two read VIs at the same time for the same session. .......................................................
Allen Liu
Lear CTC
Rliu01@lear.com
Message 1 of 1
(6,130 Views)
