VeriStand
any way to get deploy status log from API?
hello,
I made a deployment utility that allows someone to just deploy a sysdef file without using the veristand GUI. They can select IPs for each target, calibration files (optional), and click deploy. Works great. However all I display is a busy curor during deploy. Is there any way to get the text, through an API, that using the veristand GUI would normally show?
Thanks!
Stephen B
(4,994 Views)
Accepted by topic author StephenB
Yes, absolutely. VeriStand uses this exact event to populate its status information. I can't remember what it's called, but if you wire an IWorkspace2 reference into a Register for Event Callback node, you should be able to find it quickly. Something like GatewayNotification or status.
Jarrod S.
(4,985 Views)
Hi all,
Your right there are 3 events you can catch:
                    _workspace.OnGatewayErrorNotification += new DOnGatewayErrorNotification(_workspace_OnGatewayErrorNotification);
                    _workspace.OnGatewayStatusNotification += new DOnGatewayStatusNotification(_workspace_OnGatewayStatusNotification);
                    _workspace.OnSystemStateChange += new DOnSystemStateChange(_workspace_OnSystemStateChange);
I'm quite sure, "OnGatewayStatusNotification" is the one that gets the text messages displayed in the starting window.
Best regards
(4,969 Views)
Worked great thanks guys
Stephen B
(4,950 Views)
