VeriStand
confused simulation result with .Net API
Premise: All of my simulation targets are Windows(localhost).
I use VeriStand .Net API as follow:
    1. create SystemDefinition File(generate .nivssdf file with model1);
    2. new Factory();
    3. GetIWorkSpace2();
    4. ConnectToSystem(sdfpath, true, 600000);
    5. GetSingleChannelValue(varname, out val);
and I can get values correctly. but i want to change the model to model2, so i edit the sdf file with RemoveNode() and AddModel(newmodel) after call "DisconnectFromSystem("",true)". And i get a new .nivssdf with model2. Then i start from the third step. No error is displayed, but the value i get from GetSingleChannelValue(varname, out val) is the value of model1.
After i import my new .nivssdf(with modle2) in VeriStand, I can get values correctly.I think i do not clear something which is used again when i deploy my new sdf file. Help!!!
(5,922 Views)
I found that i must change the target name to get correct result when i change the model.dll. Why???
(5,892 Views)
Accepted by topic author NicoYang
I solved the problem by deleting the "/Appdata/Temp/nivs/" folder.
(5,846 Views)
