VeriStand
cs-make: *** [create_lib_dir] Error 1 When Building Simulink model
Hi all,
I'm currently using NI Veristand 2020 R6 and Matlab R2019b. I installed all the programs needed for generating models and I used to compile the Simulink model by using NI_Veristand.tlc ,But suddenly the following error appears, the error is as follows.
I also tried uninstalling and re-installing the Matlab & Veristan However, there was no luck.
D:\QLtest\so\DCMFL_niVeriStand_Linux_64_rtw>C:\VeriStand\2020\ModelInterface\tmw\toolchain\Linux_64_GNU_Setup.bat && cs-make -f DCMFL.mk EXT_MODE=0 EXTMODE_STATIC_ALLOC=0 TMW_EXTMODE_TESTING=0 EXTMODE_STATIC_ALLOC_SIZE=1000000 EXTMODE_TRANSPORT=0 MAT_FILE=1 NIDEBUG=0 NIOPT="Default" OPTS="" COMBINE_OUTPUT_UPDATE_FCNS=0 INCLUDE_MDL_TERMINATE_FCN=1 MULTI_INSTANCE_CODE=0 ISPROTECTINGMODEL=NOTPROTECTING
Setting environment for using NI Linux Real-Time 2017 64-bit tools.
DCMFL.mk:331: warning: overriding commands for target `rt_logging.o'
DCMFL.mk:312: warning: ignoring old commands for target `rt_logging.o'
/usr/bin/sh: -c: line 1: syntax error: unexpected end of file
Error(s) encountered while building "DCMFL"
Message 1 of 1
(1,320 Views)
