VeriStand
err when i want to genenate dll
I hope generate a dll in simulink, and I can succssed when the data types are int or single. But if i change the type in fixdt(1,16,1), then it wrong.
matalb version is 2010b. veristand version is 2012.
the follows are the error that display in command windows.
### Compiling the source untitled
cl -Od -DUSE_RTMODEL -DNI_ROOTMODEL_untitled -DMODEL=untitled -DRT -DNUMST=1 -DTID01EQ=0 -DNCSTATES=0 -DMT=0 -DHAVESTDIO -DNATIONAL_INSTRUMENTS_SIT -D_CRT_SECURE_NO_DEPRECATE -c -DCRTAPI1=_cdecl -DCRTAPI2=_cdecl -nologo -GS -D_X86_=1 -DWIN32 -D_WIN32 -W3 -D_WINNT -D_WIN32_WINNT=0x0500 -DNTDDI_VERSION=0x05000000 -D_WIN32_IE=0x0500 -DWINVER=0x0500 -D_MT -D_DLL -MD /MD -DNI_VERISTAND_MAINMODELFILE untitled.c
untitled.c
untitled.c(275) : warning C4013: 'pow' undefined; assuming extern returning int
untitled.c(455) : error C2065: 'sfix16_En1' : undeclared identifier
untitled.c(458) : error C2065: 'sfix16_En1' : undeclared identifier
NMAKE : fatal error U1077: '"c:\software\engineering\micro visual 2008\VC\BIN\cl.EXE"' : return code '0x2'
Stop.
C:\Users\lyw\Desktop\veristand\test\untitled_niVeriStand_rtw>echo The make command returned an error of 2
C:\Users\lyw\Desktop\veristand\test\untitled_niVeriStand_rtw>An_error_occurred_during_the_call_to_make
'An_error_occurred_during_the_call_to_make'
### Real-Time Workshop build procedure for model: 'untitled' aborted due to an error.
thank you
(5,721 Views)
the following forum thread could help you
Build Error NMAKE for simulink model
(5,702 Views)
