VeriStand
error -307663 >> NI veristand: timeout in processing request
When i start veristand project, it happen sometimes. but the project is running. How can i remove "the error -307663"??
the veristand gateway encountered an error while deploying the system definition file.
Details:
error -307663 occured at project window.lvlib:project window.vi >> project window.lvlib:Command loop.vi >> NI_VS workspace
ExecutionAPI.lvlib:NI Veristand - connect to system.vi
Possible reason(s):
Ni Veristand: timeout in processing request.
(3,658 Views)
What kind of target are you deploying to?  Does your SDF include any custom devices?
I can't find much about this error, but I would try deploying a blank SDF to ensure the issue is specific to this particular sysdef, rather than the target.
Cody A.
(3,626 Views)
I have the solution.
my veristand version is 2012.
project explorer >> project properties >> veristand Gateway setting>> deployment timeout specification
"wait for specified timeout"
Timeout = 120000 ms
I checked deploy time. if the time is over 2min(120s), this error pop up.
So, I changed timeout value 180000ms (3min).
After changing, the error does not pop up.
(3,620 Views)
