VeriStand
how can I set a setpoint following a profile?
I have to develop a function whose output is a function of the input. The input and output values ​​must be written in tabular form:
x y
10 2
12 4
15 1
20 3
I think that the only way is to build a custom device. isn't it? If yes I'd like to know if someone knows if it already exists or I have to develop it by myself.
thank you,
Fabio
(3,040 Views)
Why don't you use a csv file as the profile?
http://www.ni.com/tutorial/14020/en/
~Jiri
CLA, CTA
(3,038 Views)
Hello Jiri,
thank you very much for your answer. I think I cannot use the csv file for two reasons:
- I know that in order to use the csv file I have to add the timestamp column and in my case I don't know when I reach the value written on the first column;
- I know that when you use the csv file you set the channel value on the timestamp values and I need to interpolate the value between two rows (I hope that it is clear).
Have you got any suggestion?
Fabio
(3,035 Views)
Hello Fabio,
than you have 3 options:
Custom device
Custom model to generate stimuli
Script a stimulus profile or a ASAM XIL stimulus based on your file...
~Jiri
CLA, CTA
(3,033 Views)
So do you think that there isn't a custom device already done?
Fabio
(3,020 Views)
Accepted by topic author fabio.int
I think this one could be reused...
https://github.com/NIVeriStandAdd-Ons/SimpleSequenceSuite
J.
CLA, CTA
(2,992 Views)
