VeriStand
how to get NI veristand option in LabVIEW tools menu
HI All
I have developed a code in LabVIEW for which I want to develop Veristand model.
but for creating the model , the procedure which i followed on this forum is from LabVIEW tools go to NI Veristand and then create the model.
BUt in my LV2013 and 2012 also , I am not getting NI veristand option in tools.
I have NI veristand 2011. Do i need to select any option while installation?
I have selected LV model support also while installing.
Please help.
(6,400 Views)
You need LabVIEW 2011 to build lvmodels for VeriStand 2011. This goes for all LabVIEW plugins.
After you install LV 2011, you can re-run the veristand 2011 installer and select the model support option I believe I get the menu item you need.
Jarrod S.
(6,377 Views)
HI all
I am now having same verison of both i.e Veristand  2012 and LabVIEW 2012. Still I am not able to get NI Veristand option in tools menu. What could be the problem?
(6,052 Views)
