VeriStand
how to include custom error in VeriStand
I defined few custom error code in labVIEW when implementing a custom device for VS.
The error code file is located at C:\Program Files\National Instruments\LabVIEW 2010\user.lib\errors
The error code displays as expected in LabVIEW, but shows "undefined" error code when the device is deployed and run in VeriStand.
Attached please find the error display in labVIEW (customError_LV.PNG) and VS (customError_VS.PNG)
How to display the custom error properly in VS?
Thanks.
(7,068 Views)
Accepted by topic author MileP
MileP,
       You should be able to move your LabVIEW errors file over to the Veristand errors folder (C:\Program Files\National Instruments\VeriStand 2010\project\errors\English). Veristand should automatically check that folder for a corresponding error code when it encounters one. Try this out and let me know if it works. Thanks!
(7,047 Views)
Thank you, Grant. It works.
(7,038 Views)
