VeriStand
maximum number of frames
We are trying to deploy a system definition that has a large number of CAN frames.  We have exceeded the limit on the number of frames according to the message below.  Does anyone know what the limit is?  Thanks.
(6,697 Views)
(6,687 Views)
Hi, I definitely have fewer than 192 frames (on the port that's throwing this same error). Any other ideas? Thanks.
(6,483 Views)
I have about 50 incoming frames and 15 outgoing. My only guess is that maybe multiplexed messages somehow count toward the frame count limit? I removed a message that had many multiplexed modes, and the system deployment worked.
(6,481 Views)
I had the same problem and the maximum of frames for the NI-XNET Driver v1.6 and before is 192.
You have to download the last version of the XNET driver, 1.7 to up your number of frames to 500
XNET driver 1.7 : http://joule.ni.com/nidu/cds/view/p/id/3757/lang/en
I hope it will solve your problem,
M.CHAUVIN
(6,421 Views)
