VeriStand
merging in/out controller in vssdf
Hello, all
I wonder if there is an existing tool for merging in/out a whole controller section from/to a single target project to/from a multi-target project.
The need is to configure and tune a simulation node (that represents a part of a system) into a single RT target (this is a development system) and, when the behavior is satisfactory, to merge that project into a big multi-target system (that represents the whole system) distributed over ten or so RT targets (this is the overall simulation cell).
Best Regards.
(5,375 Views)
Accepted by topic author thumble
you can open one sysdef, select the target, select copy, then open the other sysdef, select the 'target sections' and select paste
Stephen B
(5,365 Views)
Great, Pasting as new works fine, but merging seems to enter in an endless loop (wait cursor and no CPU load). This may be because I've tried in VS2011SP1.
Best regards.
(5,362 Views)
