VeriStand
niveristand-python: Use a ChannelReference as parameter
Hello all,
I am currently working on a project using NI VeriStand 2021 R2, doing some RT measurements using niveristand-python.
The task is to measure the on-duration of several analog input channels of a PXI system.
To make my code reusable I am searching for a way to set the input channel as a parameter of the function that is calculating the on-duration.
As far as I understand, I would need to set a ChannelReference as a parameter...By now I was not sucessfull.
Does anyone have some suggestions for this?
Thank you!
PS: attached is some example python code that is working but using a fixed channel
Message 1 of 8
(4,558 Views)
If you want to reuse the python script on different VeriStand projects, you should configure all those VeriStand projects to have the same channels name.
https://tmesystems.net/
Message 2 of 8
(4,535 Views)
Well, ok...
But how can I handle different channels in the same VeriStand project without hard-coding them into the python module?
Any ideas?
Thank you.
Message 3 of 8
(4,530 Views)
You can use the user channels. Hard code the user channel name in the python script, then change the mapping in VeriStand project as needed.
Message 4 of 8
(4,525 Views)
Thank you @ZYOng for your reply.
I know I can also go with the user channels. But hard coding is not the solution I am looking for.
However, it seems there is no other way for handling this problem.
Message 5 of 8
(4,486 Views)
Hello ... Did you ever find a workaround for this ... I am trying to do the same thing but the Python implementation for Veristand is very limiting as well as incredibly non-pythonic.
Randy
Message 6 of 8
(3,351 Views)
yes I found a workaraound.
I wrote a small python script that modifies the real time sequence file (it's an xml file). It changes the Default Channel to the channel I want to test.
I am then calling this script cyclically from within a TestStand sequence.
Regards
Johannes
Message 7 of 8
(3,341 Views)
Do you mean you are changing the
<Channel Path="Hardware/Truck_Hardware_Aliases_3WS/CAN1_state" />
based on the
<Identifier>ch_can1_state</Identifier>
There has to be a better way.
Within TestStand they use the concept of FileGlobals, I am trying to figure out the equivalent in the Python implementation.
Message 8 of 8
(2,820 Views)
