VeriStand
nivsmacro file
I want to play back data in Veristand,does anyone know how the NI Veristand nivsmacro file generated?Thanks!
(2,001 Views)
Accepted by topic author bhyy
I'm not sure there is a documented specification of the xml. But if you have a look at a recorded macro file, you may understand it. (To record you must use the legacy Workspace screen, or script the API)
HAGD
(1,986 Views)
