VeriStand
reflective memory setup in Veristand
Are you very sure you're installing the 433x custom device correctly? The error code being thrown is literally not possible at all with version 6.3.1 posted online.
Stephen B
Message 31 of 54
(3,990 Views)
I deleted the old 433x custom device files and directories from the Timing and Sync Folder. Then, I followed the installation instructions in the Readme file.
I copied the contents of the newly downloaded Built folder into ...\Public Documents\National Instruments\NI Veristand 2011\Timing and Sync I then deleted the current PXI-433x Devices from the Timing and Sync node of the SDF. To be sure, I then saved the SDF and closed out of Veristand completely, restarted VeriStand, and added PXI-433x Devices back into the Timing and Sync node that I had just cleared.
I then deployed the SDF and saw the same error in the console viewer.
Message 32 of 54
(3,988 Views)
can you do me a favor and FTP into the target and delete the 433x custom device from the target?
Stephen B
Message 33 of 54
(3,985 Views)
... And possibly reboot the target. I've seen custom devices not update before the target reboots, even though the file on disk changed.
Jarrod S.
Message 34 of 54
(3,983 Views)
I FTP'd into both targets, deleted the 433x Custom Device from each one, and then rebooted both targets. When I deploy the SDF I still get the same error on Controller 2.
PatM
Message 35 of 54
(3,975 Views)
You must have some sort of software install issue. Can you make sure the contents of the NI VS 2011 Custom Devices Directory and the Timing and Sync directory do not contain multiple duplicates of the 433x device files (XML or LLBs)?
Stephen B
Message 36 of 54
(3,969 Views)
I checked and there are no duplicates in Custom Devices and the only PXIe-433x directory in Timing and Sync has Friday's timestamp (10/18/2013) on the LLB's and today's date on the XML file. There is one file "Custom Devices.xsd" in the Timing and Sync folder dated 3/16/2012.
PatM
Message 37 of 54
(3,965 Views)
Can you FTP in to your target and get the custom device LLBs and attach them here so I can inspect them?
Stephen B
Message 38 of 54
(3,961 Views)
Message 39 of 54
(3,953 Views)
Thanks.
Can you try these attached files (backup or replace the ones on your host computer then redeploy). I'm still expecting the error but hopefully I get more information
Stephen B
Message 40 of 54
(3,944 Views)
