VeriStand
run veristand project in labview- outports of simulink model dll
I have compiled a Simulink model into a dll file now I want to use some of the outports of the simulink model in labview I can see the outports in veristand workspace but now I want to use them in labview how can I do that?
(6,220 Views)
The answer depends on what you are doing with the LabVIEW VI. Is it a user interface of some sort that you want to display alongside the workspace? Or is it supposed to do some control with hardware io?
Jarrod S.
(6,202 Views)
I want to do a programm and execute that program with a PXI.
Some of the inputs of my .vi file are outputs of the dll file
I want to use this outputs in my .vi file
 is the prueba1.vi develop correct?
when I execute that program I have this error
 Error 307662 occurred at prueba.1
I don't know why it happens if the channel is correct 😞
(6,191 Views)
this is the error and the System Explorer
(6,190 Views)
There's an extra space at the end of your inport name: "Targets/Controller/Simulation Models/Models/entradasalida/Inports/entrada "
Jarrod S.
(6,181 Views)
thank you!!! now works
(6,178 Views)
now I want to execute my .vi with a PXI and I get this problem I have saved the dll. in veristand target PXI not in the Controller I have created a project and I have saved the Veristand files in C:\ of the PXI and I have the problem below I need special sofware I have installed all the avaliable veristand software in the PXI
Smiley SadSmiley Sad
(6,152 Views)
